89 choke stays on.
89 choke stays on.
My 89 montero 4 cyl has a high idle when cold. The choke stays on for 15-20 minutes. I assume it's choke, it stays at 2500 rpm. Temp gauge never reads past 1/4. Once really warm it will drop to a steady idle at 8-9 hundred. This can't be normal? I figured it was a thermostat stuck open, but that isn't it, new one just installed and same problem. It's as if the car thinks it isn't warm but heat blows hot, and engine is def at operating temp. Thoughts?
the only thing OP actually knows is that idles high then drops.
"choking the unicorn"... sounds like somthing you might pay $200 an hour at the brothel for...
Thanks, I did the coolant temp sensor before anything else, and no dice. The is a second sensor on the thermo housing with a single wire. I'll try that next. Anyone know what that one is called? Thanks for help. Its a hybrid solar/ unicorn powered motor. Cutting edge tech for 89
Jesse24
03-09-2015 01:50 PM
josenet
06-21-2013 12:41 AM
