93 montero high idle
Old 04-09-2016, 10:20 PM
coreyanton23's Avatar
Default 93 montero high idle
I have a 93 Montero with the 3.0 v6. For some reason it Idles between 1200 and 2000 rpm. Has anyone else had this problem?
Old 04-10-2016, 12:22 AM
You might have a vacuum leak. Check all vacuum hoses and air intake boot connections. It is possible that MAF is dirty, but it is more likely to act up at load and not at idle. If all that is OK, then it may be IAC issues (if equipped).
Old 04-10-2016, 12:28 AM
I have cleaned out the MAF and the IAC. I looked at most of the Vacuum hoses but that doesn't mean that I didn't miss one
Old 04-11-2016, 12:18 AM
You can try to spray starter fluid around the intake manifold while the engine is running. If you get engine to suddenly rev up - you found a vacuum leak.
Old 04-11-2016, 12:20 AM
Thanks I will definitely try that. I will post once I have tried and let you know how it goes
Old 04-14-2016, 05:06 AM
So I did that and there is not a sudden rev. Any other helpful ideas? This has been driving me crazy. I know that its not a huge deal since my truck is still running but I like to fix the little things
Old 04-14-2016, 10:58 AM
Does your truck have IAC (Idle Air Control) valve? I'd check that - disconnect the wire to it with the engine running. It IAC works properly, the engine should stumble. If you observe no changes -IAC (or wiring going to IAC) is the suspect.
Old 04-14-2016, 10:43 PM
Ok I will try that. Is there any chance of damage to the engine in doing this?
Old 04-15-2016, 11:00 PM
So I unplugged the IAC with the engine running. Absolutely nothing happened. the engine just kept running the same with no difference
Old 04-15-2016, 11:07 PM
Ok, check if there is voltage at the connector and good ground. If so your IAC is not working. If you don't have voltage (i believe it will be 5 v.) or ground you may have a wiring problem.
Quick Reply: 93 montero high idle
