99 Montero sport how to disconnect alarm - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 04-10-2013, 11:41 PM
Default 99 Montero sport how to disconnect alarm
I have a high mileage Montero Sport limited and live in Belize...no good dealers here to go to. I have a factory alarm system and would like to disconnect it. It goes off intermittently and can be disabled/reset with the dash light push button and the key in the on position. I really would just like it gone. I've searched the forum and seen some advice for an 02, not sure if that holds true for 98...wires to cut, jumper to remove and such. I don't suppose there is an easy off switch?
Thanks
Old 04-11-2013, 01:42 AM
mxmikie's Avatar
follow the wires from the ignition switch the alarm ties into the harness under the dash
Old 04-11-2013, 07:10 AM
Can the wires then simply be cut? Or does something need retired so it will start?
Old 04-11-2013, 07:11 AM
Rewired...
Old 04-12-2013, 12:44 AM
mxmikie's Avatar
cut then hooked together
Thread Thread Starter Forum Replies Last Post
98 Montero Sport Alarm Question JdpArv13 Mitsubishi Montero & Montero Sport 2 08-14-2016 04:53 PM
99 Montero Sport alarm... edes101 Mitsubishi Montero & Montero Sport 6 08-14-2016 04:41 PM
disconnect the DRL circlek Mitsubishi Outlander 0 05-07-2011 11:08 AM
Transmission fluid line disconnect MitJsus Mitsubishi Montero & Montero Sport 1 10-07-2010 05:39 PM
New Alarm, Old Alarm victim619 2nd Generation 12 02-25-2008 08:33 PM
Tags
98, 99, alarm, cut, disarm, disconnect, factory, instructions, mitsubishi, model, montero, remove, sport, step, system, video
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
