BRAND NEW ALTINATOR! and the truck still died.... I need help please :(
Does it start if you use jumper cables? If so then that indicates that the battery is not fully charged. If not then you could have bad ground wires (check the negative cables from the battery to the chassis and the engine (usually attached to the A/C compressor bracket))
One other thing as a long shot. I've had my ignition switch fail at around 90K miles. Everything worked except the starter contacts were worn. If the clicking noise is coming from around the steering column then you might want to have the switch checked out.
Ron
Ron
2000 Montero Alternator & battery lights on at all time
Greetings to all,
I'm new on this forum and looking for some help. My Montero has a new alternator about 7 months old and a new battery too. I purchased both of them last year because the Montero had an oil leek and the alternator had lots of oil. I took the alternator apart and cleaned it. However the light kept turning on so I decided to purchase a new one. Well now after 7 month is full of oil again, so I took it apart and cleaned it, the lights are still on, but apparently it's charging my battery because I can use the AC, lights and radio with no problem. Any body had this problem? Can someone help me?
v/r
Race
v/r
Race
corsair_105
10-19-2013 10:27 PM
Sweet06se
04-21-2009 02:46 PM
Shadowplane676
12-23-2005 08:37 PM
