A/C issues on 2000 Montero Sport
Old 08-27-2014, 10:17 PM
wbauer's Avatar
Default A/C issues on 2000 Montero Sport
I have a 2000 Montero Sport. It has been a great vehicle, but I have had issues with the A/C. Initially I was told by a repair shop that the compressor failed and it was going to cost a large amount of money to fix it...I changed the belts as maintenance and magically the A/C started working again! However, when the sun is out and it is a hot day(roughly 85 deg. F or over) the A/C will blow cold air for a while then it slowly warms up to about outside temperature air and gradually gets cold again for a short time. It does this the whole ride home from work..cycles cold to hot, cold to hot! Miserable 35 mins! On overcast days and slightly cooler days, NO cycling, it just stays very cold and comfortable in the cabin. The low side pressure is in the full range and no known leaks! Any thoughts?????? I am tired of hot air in the face on hot days!
Thank you for any help on things to try!
Old 08-27-2014, 10:40 PM
mxmikie's Avatar
you need to replace the expansion valve
Old 09-01-2014, 01:51 PM
wbauer's Avatar
Thank you, I will look up what that involves to see if it is something I can handle myself.
MoralDK
06-18-2015 04:37 PM
montplusrs
01-31-2014 12:45 PM
JFENDERSON91
10-10-2012 11:24 AM
titoslack
01-23-2009 02:03 PM
Quick Reply: A/C issues on 2000 Montero Sport
