Can't find coolant leak 3.8L '05 Ltd
Need help in finding the culprit of a coolant leak, it is substantial, difficult to find visually or by touch. The leak comes from between the firewall and the back of the engine, and it leaks all over the transmission, so it tells me it is right in the middle of the back of the engine. Removed the air intake plenum, and took out the top water pipe assembly. I had pressurized the system, and the heater hoses are OK. The top rigid water pipe is in good condition, and so are the o-rings. My suspects are the manifold tee behind the engine to where the top pipe connects, or another hose or smaller pipe that comes from the thermostat housing to the back of the engine that splits behind the engine that runs under the intake manifold and fuel rail, that I cannot find. In order to work behind the engine it has to be basically done blind, go by touch. So, need help with two issues:
1. How to take the water manifold tee out? Any tricks? It seems that most tools (12 mm hex) don't fit in between the engine block and the tee, as to loosen the bolt.
2. Do I need to take the fuel rail assembly and manifold out, in order to reach the lower hose/pipe that comes from the thermostat housing to the back of the engine? Mitsubishi's factory repair manual does mention having to remove the air intake plenum, but not the fuel rail and manifold assembly; not clear.
Any help and/or tricks from those who have had the fun of working on an 03-06 Montero Ltd 3.8L cooling system?
Anyone knows the name of the engineer who designed the system? So I can send him a nice e-mail letting him know how he should go back to engineering school. He probably learned somewhere that thin aluminum and rubber hoses last forever in a hot, corrosive, and oily environment.
You mean a leaking engine seal? Or the hose/pipe that runs from the water pump housing in the front of the engine to the behind the engine? Is this under the fuel rail and fuel intake manifold? As it is always my case, it can't be a simple hose or o-ring!!!
That was my initial thought and hope, but already checked and not the culprit. They are cheap, so I'm replacing anyways.
mvious
05-03-2011 04:57 PM
