Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Montero & Montero Sport
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Mitsubishi Forum - Mitsubishi Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 05-28-2006, 02:28 PM
Default changing spark plugs
How do you change the spark plugs for 2000 Montero Sport? It seems that there is not enought space to work. Is there a special tool and procedure to doit? please help.
This ad is not displayed to registered members.
Register your free account today and become a member on MitsubishiForum!
__________________
RESQ
Old 05-30-2006, 03:01 PM
Default RE: changing spark plugs
On some mitsu engines (3.5DOHC v6 for example) you need to remove the intake manifold to access one of the spark plugs. That's why you MUST USE the longest lasting plugs possible since you don't want to do that every 30K miles.
__________________
1990 3.0L SOHC V6 4 Door Montero
Custom bumpers, rocker panel protection & skids
Built for wheeling.
1989 3.0L SOHC V6 2 Door Montero
Off road virgin... about to change that <GRIN>
Old 06-06-2006, 08:42 PM
You need to get a new intake plenum gasket from your local parts store. Also, you should only use NGK Laser Iridium plugs. The will cost $12-$15, they will last for 100k miles. It takes about 1/2 hour to remove the plenum, so the entire sparkplug change job will take about 2 hours. When you are in there you might as well change the spark plug wires too. You won't see many wires that can go 10 years and 200k miles.
__________________
'90 Montero (sold-sadly)
'95 Montero LS (166k) - my car
'03 Montero Limited (36k) - wife's car
Old 06-10-2006, 03:23 AM
Quote:
ORIGINAL: off roader
It is NOT neccesary to remove the upper intake manifold on the 94-96 3.5L DOHC V6 Montero's as mentioned. There is a way which will save lots of time and effort. All 3.0L & 3.5 SOHC 24V require intake removal while the 3.0L SOHC 12v does not. All Montero Sports require intake removal.
Joel, CA
__________________
1992 3000GT VR4 & 1996 STEALTH RT/TT #47 *both tastefully modded*
Old 06-26-2006, 09:57 PM
In addition to reading the DIY section here I scanned this schematic for assistance. Even though its for the intake manifold it provides an illustration of some of the parts to remove for changing the plugs. Maybe it will help the next person down the road get an overall view of the plenum, etc. I'm gathering info myself to tackle this job so any additional tips are appreciated. Mine's a '97 Montero Sport LS 4wd, btw.
Click the image to open in full size.
Tags
35, 35l, 95, changing, forum, iridium, laser, mitsubishi, montero, ngk, plug, plugs, replace, sparg, spark, viring, vr4
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
