Cold idle to high
Cold idle to high
Hello guys n tks. For all ur help here. However I have a question for yas. When I start up my motor races up to 2000 RPM. Then when it gets warm it goes back to normal. Tks.
Mitsubishi montero sport XS 3.5 2001.
Ok so here we go on the COLD high idle!!!!
Ok, I have the question into yahoo Q&A and will keep yas posted.
OK... Here we go again... I should have posted this also but just forgot...
I noticed the Montero getting slightly louder, then the idle started to get higher and higher ...
Now it's at about 2300 RPMs only when cold then warms up after a few minutes and goes right back to normal. I took apart/cleaned all the sensors, checked out all the vacuum hoses ( all good ) I have 125,000 miles on my baby now. I was waiting to do a tuneup on it cause if you look for trouble YOU WILL ALWAYS FIND IT. LOL. Now keep in mind I change the oil every 3000 mi. or before any trips and it is very well maintained too. Thanks for your time here as this is still a very big help for me.
UPDATE...I GOT THE FIX WITH BEAUTIFUL PICTURES UNFORTUNATELY THE FORUM WILL NOT LET ME POST FROM MY DESKTOP SO NO PIC'S HERE BUT YOU CAN EMAIL ME AT... handson59842@yahoo.com and I will send them to you.
Now I had 2 bolts that rusted almost all the way off of the catalytic converter so I removed the rest and put some bolts through and tightened them up with no leaks now. It was right by the oxy sensor so I guess that was the culprit that was giving me a false reading. Once again my Montero runs fantastic.
I would still like to thank AKZLE and HUNTERD for your help in this matter.
wilde
11
09-29-2015 11:33 PM
Raquel
03-26-2011 11:03 AM
yamahablaster8230
08-29-2006 09:28 AM
