Crankshaft pulley
1. On Montero Sport models, remove the undercover skid plate. See Fig. 2 . On Montero models, remove the undercover only.
2. Remove the cooling fan lower shroud. See Fig. 3 .
3. Use special tool MB991367-01 spanner wrench (use with MIT217213 pins for Montero Sport; use with MIT217212 pins for Montero) and a 22 mm socket to hold the crankshaft pulley in place. Remove the crankshaft pulley bolt.
4. Inspect the crankshaft pulley bolt. a. If the bolt is damaged, replace it (see PARTS INFORMATION section of this bulletin). Then continue with step 5 below. b. If the bolt is NOT damaged, go to step 5.
5. Clean the crankshaft pulley bolt hole, the bolt, and washer with compressed air.
6. Apply engine oil to the bolt threads and between the washer and the bolt head faces shown. See Fig. 4 .
7. Reinstall the crankshaft pulley bolt. Torque to 182 + 4 Nm (134 + 3 ft lbs).
8. Reinstall the lower shroud.
9. Reinstall the undercover and skid plate.
Or check this page:
6G74 3.5L DOHC Pajero Cambelt-service - 4x4 Community Forum
Or check this page:
jx_mirage01
06-14-2008 09:02 AM
