Differential noise / whining
Old 10-02-2010, 11:43 PM
redsmonty's Avatar
Default Differential noise / whining
I have a 2002 Montero XLS 4x4. The rear Diff./ carriage is making whining noise. The right rear axle has a 3/8" (10mm) gap where it looks as if the axle has pulled out of the rear diff. Is there any shear pins or snap rings ("C" clips) in the design that could be the cause of the issue? Any advice or suggestions will be helpful I'm sure. Will any rear diff. from a Montero work, or did they come with various ratios? Will a Montero Sport work? What is the range of years that will work?
Thanks in advance.
sdhot5
06-30-2015 02:17 AM
Lithium
11-16-2009 05:44 PM
RBasque
01-27-2009 02:01 PM
jeff
03-19-2008 10:41 AM
classicol
11-23-2007 06:55 PM
Quick Reply: Differential noise / whining
