ecu idle reset/relearn HELP!!!!!
how do i reset my computer when i unplugged my battery now the idle is crap like 300rpm i read that you have to let it idle but ive done that and nothing yet any advice? any instructions?
As far as your idle, my bet is that it needs to be relearned. Every time you unhook your battery you have to go through an idle relearn procedure. ..its really annoying and I have never owned another vehicle that needed the idle to be relearned when the battery is unhooked. So do this and see if it still wants to die out on you afterwards.
Relearn procedure
"Make sure that all accessories are turned off, a.c. radio, lights etc.."
That is very important as the bcm will learn the wrong idle speed and you will find yourself in the same position.
1. Unhook the battery for a few minutes and then hook back up
2. From a cold start. Turn the ignition to the acc position for 20 seconds and then turn back off.
3.start the engine with no accessories on and let the engine idle from cold to normal temp for 15 minutes.
4. Shut the engine off.
5. Turn the ignition to the acc position and then back off.
6. Start the engine and let it idle in park for 3 minutes.
7. While engine is still running hold in brake and put it in drive. With brakes pressed it the engine idle in drive for 3 minutes.
8. Put the car back in park and shut off for 20 seconds.
9. Start the engine.
10. Finished
Pretty annoying huh?
That should take care of your idle and if not then a further problem exists.
Hope this helps.
Post back and let me know if it worked
Cheers
Relearn procedure
10. Finished
Hope this helps.
Cheers
ok so i found it search is a nifty little thing (0 before anyone else says it.)
I have a similar issue with my 2003 Montero Limited.
All things pointed to a defective idle valve?
Picked one up at the auto parts house
and they must have given me one for a Sport
for it looks nothing like mine.
Only acts up once the vehicle has warmed
to normal temps.
Could your problem be the IAC?
to normal temps.
codeaholic
11-01-2016 07:47 PM
