Harmonic Balancer Nightmare
Old 12-16-2010, 01:53 PM
tOYBOX13's Avatar
Default Harmonic Balancer Nightmare
Help!!!!! I removed the hormonic balancer from my 1999 Montero Sport 3.0 engine and the timing gear came out with the balancer is this supposed to happen.How do I get the timing lined up again, and How do I get it off of the balancer does a new one come on a replacement balancer,Please help, this is my only car....Tom
Old 12-16-2010, 10:27 PM
Obakemono's Avatar
No, they are two different parts. Why where you removing it anyway???
Old 12-21-2010, 06:20 PM
tOYBOX13's Avatar
tHEW DAMPER PULLEY FOR THE SERPENTINE BELT CAME OFF OF THE DAMPER.WHEN I TRIED TO REMOVE THE DAMPER THE LOWER GEAR CAME OFF WITH IT.I FINALLY REMOVED IT FROM THE DAMPER AND NOW I AM IN THE PROCESS OF PUTTING IT BACK ON, AFTER I TORE APART THE FRONT OF THE MOTOR.IS THIS A COMMON PROBLEM WITH THE GEAR COMING OUT WITH THE PULLEY.IT WASLIKE IT WAS PRESSED ON.THE OLD GEAR FITS RIGHT INTO THE NEW DAMPER.
420a
11-04-2007 09:03 PM
420a
10-29-2007 08:55 PM
sci_v_ici
1st Generation
14
04-17-2006 02:02 AM
cptkid570
12-14-2005 12:59 PM
Timmay
09-26-2005 06:15 AM
Quick Reply: Harmonic Balancer Nightmare
