Go Back   Mitsubishi Forum - Mitsubishi Enthusiast Forums > Mitsubishi Models > Mitsubishi Montero & Montero Sport
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Mitsubishi Forum - Mitsubishi Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-19-2010, 08:44 AM
Default Error Code P0173-Fuel Trim Bank?
I got two error codes, P0173 and P0125. I thought the cause of the P0173 was the P0125. However the ECT is fine, and I just replaced the thermostats, coolent is full.
So now I'm guessing its the P0173 causing the P0125. Autozone can't tell me what a P0173 is for a mitsubishi is. However, for a Kia its a problem with Fuel Trim Bank 2. Whats a Fuel Trim Bank?
This ad is not displayed to registered members.
Register your free account today and become a member on MitsubishiForum!
Old 12-20-2010, 03:48 AM
The following should help explain:
http://www.obd-codes.com/p0173
Old 12-20-2010, 09:55 AM
Yeh, it sounds pretty innocuous and can be a lot of things. It definitely is "heat" sensitive. I thought it was fixed as the light went out. However, after a long hard drive yesterday with the car heating up a bunch, the light came back on.
Old 12-20-2010, 10:16 AM
Wow the Mass Air Flow sensor is $300. Thats a lot to spend on a "maybe".... It doesn't make sense that the mass air flow sensor would work some of the time and not some of the time. I would think this particular part would be an all or nothing.
Old 12-21-2010, 10:24 AM
I guess I'll start by cleaning the MAF sensor. If that doesn't work, then I replace the O2 sensor.
Tags
99, bank, code, codes, eclipse, error, fault, fuel, galant, mitsubishi, montero, p0173, po173, sport, trim
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
