help help
Old 12-13-2010, 07:50 AM
CHIKE's Avatar
Default help help
my 2005 motero limited throws code P0720 , it looks like transmission problem but where should i start? can someone help me
Old 12-13-2010, 09:40 PM
Mr. Z.'s Avatar
Can you describe what is going on with the rig?
How long has it been since you've flushed the system and changed the filter?
Old 12-15-2010, 09:57 PM
jgbrules's Avatar
p0720 is the trans output speed sensor code. fluid and filter change WILL NOT affect this. gotta replace the sensor. dealer item only.
Old 12-16-2010, 02:30 AM
CHIKE's Avatar
Smile P0720 ,p0305 help
the trasmission takes long before it will shift,and the N light flashes while in Drive. anyway i have discovered " broken power wire " to the output speed sensor and joined it. now it works fine . MIL light disappeared.
after two days MIL light appeared, Cylinder 5 misfire , i ve just cleared the computer to drive and monitor the engine perfomance. i also just need
to identify which of the cylinder is no.5 . can you help on this MR. Z ?
Old 12-16-2010, 02:40 AM
CHIKE's Avatar
P0720,P0305
to identify which of the cylinder is no.5 . can you help on this, GUYS?
Old 12-16-2010, 06:08 PM
Mr. Z.'s Avatar
Check out this Russian site.
The have the FSM for a number of Montero generations.
http://www.pajero4x4.ru/
