Eco mode
Old 01-05-2022, 01:43 AM
samifahad's Avatar
Default Eco mode
Hi everyone. Is there away to deactivate eco mode in Montero sport 2021 gas?
Old 01-05-2022, 04:42 AM
DibbyDibbyDJ's Avatar
Is there an ECO mode button?
Or does it just show ECO on the display sometimes?
Old 01-05-2022, 08:10 AM
samifahad's Avatar
Default Echo mode
In former models mainly in 2016 to 2019 there is afunction in the configuration menu for able/disable eco mode.But the newer models don't have such function.
Old 01-05-2022, 06:11 PM
Naeos_Valkarian's Avatar
The dealership may need to access the ECM with their software to enable/disable certain settings. However, this does not mean they can or will disable anything that has to do with emissions. Eco mode is a unique way manufacturers have come up with in order to pass certain emissions criteria while also allowing themselves the benefit of advertising Higher MPG. There may also be a sequence of pedal/switch presses, or a hidden menu somewhere. Wouldn't do any harm to ask the dealership if they know how or are willing to disable it, worst they can say is no.
Also, I'm assuming you've read through the users manual?
Old 01-05-2022, 07:47 PM
samifahad's Avatar
You are right. Asking the dealership will provide an answer. Thanks for your reply.
crazy nurse
04-16-2019 05:45 PM
Clarke845
07-06-2016 06:13 AM
thrustbucket
02-17-2013 10:32 AM
Win
Other Mitsubishi Models
07-26-2012 05:37 PM
Russianfart
03-16-2008 02:21 PM
Quick Reply: Eco mode
