Montero Info Collection
Old 02-22-2015, 06:06 PM
ricardohd91's Avatar
Exclamation Montero Info Collection
I got 95 Montero and its smoking like a coal steam engine. Goes through 1 quart of oil a week... Yup. So, time to mod. From what I've seen on these forums, people hate anything non-mitsu, so i won't concentrate on that. Rather I want to find as much info as i can pertaining engine bay space, axle ratios, transmission tunnel space, drive shaft lengths, shaft orientation, rotation, transfer case ratios, and the sort.
Most importantly, engine bay spacing. I'm not a fan boy of anything, so if i can get my hands on a good reliable engine that can fit with any trans and keep the 4x4 working correctly, then ill go for it.
I have the 3.0 SOHC with 4 speed auto, i will start measurements soon on engine transmission and engine bay. If anyone has a 3.0 or 3.5 engine out of vehicle, that would facilitate alot of things.
Radiator to firewall:
Side rail to side rail:
Axle to hood:
Engine mount spacing:
Engine mount height (use axle as reference):
Engine mount to top intake plenum:
Will add as needed.
3.0 SOHC Dimensions
Head edge to head edge:
Block width:
Oil sump to top of upper intake (lowest part to tallest):
Cooling fan to rear of engine:
Water pump to rear of engine:
Axle to sump clearance:
Intake to firewall clearance:
Will add as needed.
3.5 DOHC Dimensions
Block width:
Will add as needed.
Drivetrain specs:
Front Axle Ratio:
Rear Axle Ratio (non-locking):
Rear Axle Ratio (locking):
Transfer Case Ratio:
Crankshaft pulley to rear output shaft:
Output shaft to Rear axle flange:
Front output flange to from axle flange:
Front output off-center measurement:
Transmission at widest point:
Transmission at thinnest point:
More will be added as info is collected.
EMonz57
09-18-2007 06:23 AM
Chris BE
04-19-2006 01:23 PM
Chris BE
04-06-2006 03:36 PM
Chris BE
04-06-2006 03:33 PM
tidus10
03-31-2006 10:12 AM
Quick Reply: Montero Info Collection
