Montero Sport Fuel System Diagram
Old 09-21-2013, 09:38 PM
tero's Avatar
Default Montero Sport Fuel System Diagram
Is this correct?
Old 09-23-2013, 07:13 AM
tero's Avatar
Can someone please verify on their Monty if D & E are correct. Thanks
Old 10-03-2013, 02:24 PM
tero's Avatar
this forum is absolutely terrible... sorry just had to get that out of the way.
For anyone who cares, the diagram above is correct.
Also, I learned a 2001-2004 fuel pump assembly will fit an early 2000 MS. Everyone said it would not fit, but the pictures looked identical online so I ordered it and it was exact same part. Airtex made the pump #E8439H.
Your welcome
Old 10-07-2013, 02:54 PM
tero's Avatar
before/after
Old 03-30-2017, 01:34 AM
fikse's Avatar
I am into fixing my MS fueltank. These pictures and desription helped alot. Thank you
Old 09-22-2019, 02:35 PM
Kprof's Avatar
Default Thanks for sharing this
I am the happy 2nd owner of a Montero xls sport i am replacing the filler neck and your diagram helps me if i do the complete fuel system thanks any more reference here is appreciated
Im in nj . Am getting ready for inspection and am anticipating all the details
Old 09-24-2019, 01:33 PM
Kprof's Avatar
Default T
Does anyone know if this fuel tank is obsolete or not produced by any after market company a reply would be appreciated .
I did get the filler neck from Mitsubishi parts inc in Florida they were knowledgeable just need the last 8 digits of the vin .hopefully my post is a helpful contribution here .
My Montero xls was deceptively sold to me i will persevere through the repair its a nice vehicle . Thank you . Kprof
Old 09-25-2019, 04:52 AM
larry4406's Avatar
Not sure of your year, but here is a link for a new OEM tank for a 2002 Montero Sport XLS, 2002 Mitsubishi Montero Sport Parts - Fuel Tank - MN120735, for $868.74. Says it includes the sending unit. I assume it does not include the pump
https://mitsubishiparts.com/2002-mit...MN120735-item/
Old 09-25-2019, 05:00 AM
larry4406's Avatar
Here is a diagram from the manual. Hope this helps.
Old 11-11-2019, 10:03 AM
Kprof's Avatar
Default Fuel tank
This is the tank from a 1999 monti sport xls feb 99 build date
I did this job its pretty easy to remove . I replaced the rubber lines with new my issues were with the connection to the fuel filter i kept having a leak its pretty scary it sits it runs pressure tests no leak then the next morning after a warm up and drive it spews out the repair fittings . Any help with this one is appreciated.
ExtremeHobo
05-05-2016 09:15 PM
jazciel
05-29-2014 01:10 AM
jallert
06-09-2012 10:21 PM
fitenfire4life
11-13-2011 08:49 PM
mieszkoj
08-10-2005 04:24 PM
Quick Reply: Montero Sport Fuel System Diagram
