Motero 3.0 V6 Oil Pressure ??
Old 01-23-2009, 04:56 PM
tdf's Avatar
tdf
tdf is offline
Default Motero 3.0 V6 Oil Pressure ??
I have a high mileage engine and the Oil Pressure gauge shows much lower than spec oil pressure. At idle almost nill.
So far no damage. The engine has had lots of maintenance and the top end (heads) I know have been reworked.
Is it common for the 3.0 oil pump to wear out or am I more likely looking at worn bearings and a need to rework the crank and replace main and rod bearings?
This is my 1st experience with the Mitsubishi 3.0!
Old 01-24-2009, 12:03 PM
Manybrews's Avatar
Default RE: Motero 3.0 V6 Oil Pressure ??
may help if you tell us what year you're driving.
but chances are it needs nothing. Mitsu v6s NEVER wear out unless neglected or abused.
Old 01-25-2009, 12:54 AM
4g54's Avatar
dirty engine oil can cause the reading to be lower than normal.
another possible cause is the oil pressure sensor but this sensor hardy fail.
Old 01-25-2009, 04:07 AM
Skiddy's Avatar
Maybe you have dirt built up inside the engine? How many miles on it?
Old 02-14-2011, 11:41 AM
poloam82's Avatar
Default help
where is the oil pressure switch located in a 2000 montero sport v6 3.0?
Old 02-16-2011, 10:56 PM
jgbrules's Avatar
at idle the spec on that motor is 9 to 11 psi when warm.
miamiguy1105
06-20-2012 05:25 PM
zonarosso
10-19-2010 09:40 AM
Tbone4JC
06-03-2010 09:07 PM
XLSmontero
09-01-2006 12:19 PM
Quick Reply: Motero 3.0 V6 Oil Pressure ??
