need help rough idle
Old 10-11-2014, 11:45 AM
quechon's Avatar
Default need help rough idle
Hello i just change my spark plugs wire and now im getting a rough idle (misfire) what you guys think is causing that before i take everything apart again btw i didnt change spark plusgs just wires
Old 10-12-2014, 08:58 AM
jhill15's Avatar
Could be as simple as a faulty wire. Is it possible you didnt get the wire pushed down on the plug all the way, or accidentally switched one of the wires to a different cylinder? ??
Old 10-12-2014, 09:57 PM
Check the wires to maake sure they are plugged in the right order. Do you have a diagram for that? Also, use a small mirror take a peak under the intake plenum to look at the wires going to the spark plugs. See if one of them is not seated all the way (it'll be higher than others and touching the plenum). It is possible that it popped off and is not providing a full spark every time. If you were to get a check engine light, the code may help to narrow down which cylinder you are having an issue with.
Old 10-13-2014, 05:33 AM
quechon's Avatar
Thanks guys didnt plug them in the right order
glttrybuttrfly
08-18-2005 11:18 AM
matt02708
06-12-2005 10:24 AM
96EclipseGSX
02-14-2005 09:07 AM
outlancer
12-11-2004 09:36 PM
Salazar
10-04-2003 09:36 PM
Quick Reply: need help rough idle
