New Member, Lurching Problem
Old 12-29-2013, 04:48 PM
acd238's Avatar
Question New Member, Lurching Problem
I recently purchased a 2001 Montero Sport Limited (automatic trans., 3.5L engine, 70K miles). Recently, it has been acting odd. When I start the car for the first time in the morning, it will "lurch" into gear. Here is a detailed explanation of the scenario. I will get into the car after it cooling all the way down overnight, and then start the car. I wait for the car's RPM's in park to drop below 1K. Then, I will put the car into gear. When I do this, the RPM's will jump up. I keep my foot on the brake, and then the car will suddenly lurch forward 2-3 seconds later. I believe the lurching is the transmission engaging. After noticing this problem for the first time, I have begun to place the car in neutral as soon as the RPM's jump up. If I shift back from neutral to drive, sometimes the car will drive fine. I should explain that this problem ONLY happens when the car is cold. I have never had an issue once the car is warmed up.
I would appreciate any help or advice any of you members have. I'm in a real quandary.
-Thanks
Old 12-29-2013, 07:26 PM
Dennryan's Avatar
Have you scanned for any codes? Are the moter mounts good?
gggplaya
06-30-2015 06:04 AM
Neverarine
03-19-2012 09:00 PM
westerlundjc
12-14-2009 07:20 PM
cpark
11-04-2009 10:33 PM
Quick Reply: New Member, Lurching Problem
