O2 sensor (bank 2) - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 01-03-2009, 11:43 AM
Default O2 sensor (bank 2)
Could any one tell me what bank 2 refers to. Montero failed inspection because of it. I know there are 4 o2 sensors on the car. I don't want to replce all for just to replace one of the sensors. any help would be great. if bank one is one of the engine and bank 2 is the other side I'll take that. info. replacing 2 is still cheaper than 4.
thanks,
Albert
Old 06-13-2009, 07:28 PM
This post is WRONG!----->(((bank 1 refers to the driver side cylinder and bank 2 for the passenger side, if the error is bank 1 sensor 1 that is the sensor on the driver side pre cat converter. bank 1 sensor 2 would be the post cat. bank 2 would be the right side and so on.))) SORRY!
if ever there are more sensors then that will be bank 1 sensor 3 and so on
But this part is CORRECT ----->> black connectors wont fit into gray connectors
tags: PO155, PO161, Heater Circuit Malfunction
Old 06-17-2009, 09:14 PM
bank one on a montero or a montero sport is on the passengers side. bank two is obviously on the drivers side. dont know what info xyzik got, but he is wrong. sensor one is before the converter, sensor two is after the converter. each bank has two sensors. on each bank there is a sensor with a black and a gray connector, and no they will not interchange. connectors are different.
Old 03-01-2012, 04:36 PM
Default O2 Sensor Placement and Connector Locations
Sorry for the wrong info and taking a while to correct it, I took pictures and added sensor and connector locations.
Tags: Mitsubishi, Montero, 2003, O2 Sensor, PO161, PO155, PO141, PO135
 O2 sensor (bank 2)-capture.jpg    O2 sensor (bank 2)-img_3037.jpg    O2 sensor (bank 2)-img_3046.jpg
Old 09-03-2013, 11:07 PM
From the last picture it doesn't look like the sensor is attached to the pipe. Or is this disconnected?
Old 07-02-2016, 02:05 AM
Quote:
Disconnected.
Thread Thread Starter Forum Replies Last Post
left bank vs. right bank fireman53d Everything else 1 01-30-2014 07:55 PM
Tags
1998, 2003, bank, eclikpse, eclipse, endeavor, location, mitsubishi, montero, o2, oxygen, po161, sensor, side, sport
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
