OBD ll CODE P0300
Old 09-28-2006, 08:24 PM
ajav05's Avatar
Default OBD ll CODE P0300
Please Help I have a 97 Montero SR with code P0300 ( Ramdon/Multiple cylinder misfire) and my question is What cause this problem and how can I fix it?[sm=helpout.gif]
Old 09-28-2006, 08:44 PM
Default RE: OBD ll CODE P0300
Coil pack im willing to bet. Its something in the ignition system. Its either plugs/wires or the coil pack.
Old 10-01-2006, 10:05 AM
ajav05's Avatar
Thanks SEBBA for your reply, but for some reason the "check engine" light is off now and how easy is to change the coil pack?
Old 10-01-2006, 02:32 PM
Fairly simple... its on the other end of the spark plug wires... just unhook it... and replace it and hook eveyrthing back up... its that simple. Just make sur you put the spark plug wires back on in the right order.
It may just be your plugs or wires. I would change those.
WackJobRacing27
12-28-2020 09:15 PM
galant00owner
05-24-2012 07:21 PM
ciproxin
03-09-2012 12:25 PM
Navydude246
07-29-2011 07:23 PM
Stryker
09-16-2007 08:36 PM
Quick Reply: OBD ll CODE P0300
