firing order wrong
Old 11-21-2010, 05:07 PM
CharlesT's Avatar
Default firing order wrong
i recently rebuilt my engine in my 1993 mitsubishi montero sport 3.0L V6
i got the timing set correctly with the marks shown online and in my chilton's book i set the timing on the ditributor and it's out of time. ive tried hundreds off diff ways i know the timings good not shure about the timing on the distributor. online it says my firing order is 1-2-3-4-5-6
back of engine
5-6
3-4
1-2
front of engine
but the distributor cap says 1-2-6-4-5-3
going clockwise
chiltons says
1-3-5-6-4-2
counterclockwise
the dizzy goes clockwise not counter-clockwise
ive tried about with no avail im completely sick of this truck at this point but i am still hopefull. if anyone knows how the dizzy and wire's are really supposed to go id owe you forever thanks in advance Charlie : )
Old 11-22-2010, 10:12 PM
CharlesT's Avatar
replaced my dizzy still no luck. also i tore apart 3 other v6 mitsu's at the junk yard all of them are the same as my timing setup.
Old 11-23-2010, 08:28 PM
johnoutdoors's Avatar
Bring #1 piston to TDC on the compression stroke and put the distributor in with the rotor pointing to #1 plugwire on the cap and see if that helps it.
Old 11-24-2010, 09:50 AM
CharlesT's Avatar
I'll try that think i already have though. all the ones ive torn down at the junk yard point to the heater hoses on the firewall #6 pos.
Old 11-24-2010, 07:54 PM
CharlesT's Avatar
tried it didnt work. also i pulled all my plugs hooked them up to the wires and shocked myself 6 times for a good cause they all were in working order.
brethankes
11-22-2010 08:48 AM
ZaVaZ
06-27-2009 03:48 PM
dravenjun
11-25-2005 06:45 PM
Wesvr4
08-13-2005 04:34 PM
jimmydg45
05-28-2005 06:23 PM
Quick Reply: firing order wrong
