Replacing valve guides and stem seals - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 02-12-2009, 05:26 AM
Default Replacing valve guides and stem seals
What else would it be advisable to replace when replacing the two? I've already bought valve cover gaskets, and have been told to replace the oil seals. Anything else to add to the list? Thanks.
Old 02-12-2009, 05:47 PM
Default RE: Replacing valve guides and stem seals
you cant replace valve guides without cylinder head removal. So you'll need an entire upper engine gasket kit. Also, it would be helpful if you told us what you're driving.
Old 02-13-2009, 04:13 AM
Sure, it's a 2000 Pajero/Montero with a 12-valve 6G72.
Old 03-05-2009, 12:09 AM
You will also probably need to recut the seats and grind the valves if they are not new to make sure there is a good seal between the two. When you replace the guides the center point can change enough to cause problems.
Thread Thread Starter Forum Replies Last Post
changing valve stem seals quechon Mitsubishi Montero & Montero Sport 8 10-13-2014 06:14 AM
simple tire valve stem question newoutlanderfan Mitsubishi Outlander 6 08-20-2013 07:47 AM
1996 Montero 3.5 VALVE STEM SEALS & Rebuild Videos drakerr Mitsubishi Montero & Montero Sport 4 01-20-2013 04:42 PM
12V Valve stem seals Skiddy Mitsubishi Montero & Montero Sport 0 11-26-2008 09:41 PM
Estimate to replace valve stem seals? dksnj Everything else 1 01-02-2007 01:41 AM
Tags
3000, 3000gt, diamante, guide, guidesmitsubishin, installing, mitsubishi, recut, replace, replacement, replacing, seals, seats, valve, valves
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
