slow voltage drop then back to normal
For the last couple of days when I'm driving home the dashboard, headlights, etc. will slowly get dimmer and dimmer. Then the radio turns off. Then the SRS and other idiot lights come on.
So I pull over and stick it in neutral and wait a minute or so. Then all of the sudden everything comes back on and it's back to normal.
I'm thinking alternator. I've replaced the alternator twice in the last three years. Do montero sports eat alternators that badly or is there something specific to my car that could be prematurely killing them?
Looks like it's probably oil contamination that's causing the string of bad alternators. Found someone else say that the front cam seal leaks oil directly onto the alternator and ruins it. This sounds like my issue since I definitely have a leaky valve cover. It's not a stretch to think that the cam seal needs replacing as well. I've been putting it off. I guess it's time to break out the tools and start replacing gaskets/seals.
gormleyp
02-05-2015 03:34 AM
raycam2kx
11
10-12-2007 06:08 PM
01, alternator, back, car, contamination, drop, drops, eclipse, mitsubishi, montero, normal, oil, returns, slowly, voltage
