help help
P0720 ,p0305 help
the trasmission takes long before it will shift,and the N light flashes while in Drive. anyway i have discovered " broken power wire " to the output speed sensor and joined it. now it works fine . MIL light disappeared.
after two days MIL light appeared, Cylinder 5 misfire , i ve just cleared the computer to drive and monitor the engine perfomance. i also just need
to identify which of the cylinder is no.5 . can you help on this MR. Z ?
P0720,P0305
to identify which of the cylinder is no.5 . can you help on this, GUYS?
Check out this Russian site.
The have the FSM for a number of Montero generations.
http://www.pajero4x4.ru/
