timing belt mark
timing belt mark
"on a 2002 mitsubishi montero sport. when the crack shaft pully is instlalled, where should the timing mark on the pully line up on the timing tab located on the accessory mounting plate when the cam sprockets are in time? 4-5 degrees before tdc or after?"
