urgent help! montero harmonic balancer keeps comming loose!
Old 06-11-2011, 09:51 PM
deziking's Avatar
Default urgent help! montero harmonic balancer keeps comming loose!
It's an 2000 Mitsubishi Montero Sport ls v6 3.0 found out no power steering and battery light popped on so checked the belt first the alternator belt was loose so I retighted it, started it up turn the wheel.... suddenly lose of power steering and start hearing noise. I turn off the car and now the ps belt is loose. So I took both out and harmonic balancer is loose as crap! So i try to retighten the best as possible without moving the pulley. But **** still comes off! I've heard they have recall for this for a new bolt they had designed is this correct? and use proper torque and tool? Thanks for your time!
Old 06-11-2011, 11:44 PM
mxmikie's Avatar
yes that is right
Old 06-12-2011, 12:48 AM
deziking's Avatar
oh forgot one more thing! the woodruff key is broken on the crankshaft sprocket!!! Who ever worked on it last did not torque the crankshaft pulley bolt to right spec. Arghhh how do I fix this without disassemble the timing belt? Easy solution on the car??
Old 06-13-2011, 08:13 AM
mxmikie's Avatar
your going to have to remove the timing belt to change the crank key and hope the crank key way is not bad
Old 06-13-2011, 12:32 PM
deziking's Avatar
Okay thanks!
Old 08-28-2019, 01:50 PM
Dr. Cloudpiler's Avatar
Default Damaged Keyway ??!!
I have the same problem and a mechanic told me I need to replace the engine. That can't be true. If the keyway is worn or damaged, is there no way anybody can repair that?
Old 08-28-2019, 09:34 PM
Several things to pay attention:
1. if your key is broken, the harmonic balancer could have moved (rotated) along the timing gear. This is what allows the bolt to unscrew over time. At the same time, the rubbing of HB on timing gear may have worn out grooves on both. This prevents proper mating of the surfaces when re-installing and contributes to continued situation of bolt coming out. I had similar situation where the key broke. I replaced the key and was able to re-use old HB and old timing gear. After awhile the HB came loose again. After repeating the cycle several times, I sprung for a new harmonic balancer and new timing gear. Never had an issue since.
2. Recall for the HB bolt is for a design that is less likely to break leaving bolt threads inside the crank shaft. It would be a good idea to put a new bolt on the unit, but it's not going to solve your situation if you are re-using old harmonic balancer and old timing gear.
3. Make sure you PROPERLY torque the HB bolt. Its supposed to be somewhere around 130+ ft. lbs. If it's less than that - it will keep coming off.
Old 08-29-2019, 12:04 AM
That sounds exactly like what's going on. New hb, key and bolt I think. No sense messing around. Thank you!
Harvey32
07-22-2015 06:24 PM
Harvey32
07-21-2015 10:27 PM
Lobosmom1
09-05-2012 02:08 PM
cptkid570
12-14-2005 12:59 PM
Timmay
09-26-2005 06:15 AM
Quick Reply: urgent help! montero harmonic balancer keeps comming loose!
