Valve Lash Adjuster Installation
Hey guys, been lurking for awhile picking up some good info, but I'm having a problem and can't find an answer using the search function.
1990 Montero(base)
3.0 V6
I'm in the middle of replacing the head gaskets and figured that I would go ahead and check the valve lash adjusters for anything out of the ordinary(one was being noisy). Well, I figured that they would all be the same so I didn't make note of which adjuster came from which valve. A couple of the adjusters have a wider band in the middle of them and seem to compress quite a bit more. Any help figuring out where each of these go would be greatly appreciated. I can probably post a pic when I get home if that would be helpful. Also, I've only taken apart the driver side. I'll be more careful on the other side! TIA.
1990 Montero(base)
3.0 V6
simjack
04-22-2008 11:16 AM
Scottrik
09-14-2005 06:52 PM
