'07 xls - ASC off - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 10-27-2008, 09:15 AM
Default '07 xls - ASC off
'07 xls 4WD 23,000 miles
info screen diplaying "service required - ASC off "
this is not being displayed with the "check engine" light.
displays right after start up. ASC button is not being pushed.
looked in all diagrams to see if ASC had its own fuse ,could not locate a fuse related to it.
dis-connected battery , then re-connected. "service required" popped right back up after re-starting.
Anyone have any suggestions ( besides the obvious "take it to the dealer" ) i'm sure i will end up doing that when time allows.........probem is , that may not be for a couple of weeks.
Old 10-29-2008, 04:49 AM
Default RE: '07 xls - ASC off
if its anything like other automakers it will continue to come on until you take it to a service department and they actually reset the warning in the computer
Old 10-29-2008, 09:07 AM
i am sure i will end up taking into dealer service when i can free up the time.
i was just hoping that someone might know what the ASC in "linked" to.........
.......so i could look for a loose connector , broken wire , bad relay , or blown fuse ! !
Old 10-30-2008, 08:01 AM
I check the shop manual, There are a lot of components that make up the ASC system, I would check the following fusible links and fuses.
Fusible link: 26, 27, 33, 34
Fuses:2, 5, 9, 12, 30
Old 10-30-2008, 01:11 PM
i figured it would be a complicated system.
so far i have only been able to pull the activation button an check it. (it is o.k. )
thank you for the information on the fuses and links.
Old 10-31-2008, 12:25 AM
my 07 outlander xls 2wd had the same issues .. and here is my reply ...[/align][/align]Got my outlander back ... the dealership replaced "Angular Velocity Sensor" for this "ASC Turn OFF" issues ..
took about 5 hours to replace the parts and is FREE [/align][/align]
Old 10-31-2008, 02:24 AM
Speaking of engines, anybody knows what kind of "belt" is used by the CVT mated with 2.4 engine. Is it a rubber/steel belt like the one developed by Nissan/Subaru or is it a pure steel belt like the Multitronic developed by Audi??
Old 10-31-2008, 09:41 AM
cybergoogle.......thanks for that info. now i will have something to pass along to service when i take into the dealer.
dger.........what does the belt for the CVT have to do with the "automatic stability control system" ?
Old 11-07-2008, 03:24 PM
there is the consumer information about newly developed 4B12 engine:
http://www.mitsubishi-motors.com/cor...006/18e_09.pdf
Old 12-06-2008, 09:03 PM
..dealership replaced the angular velocity sensor today.
it did NOT solve the problem.
now they need to go back to "poking and probing" to find out why my outty thinks the ASC is off.
Thread Thread Starter Forum Replies Last Post
HELP! 07 Outlander ASC OFF, SERVICE WARNING, BATTERY DEAD, STUCK IN 3RD GEAR! HELP! nbgsultan Mitsubishi Outlander 2 03-19-2013 06:41 PM
ASC off switch edurbeck Mitsubishi Outlander 18 07-13-2012 02:59 PM
Software glitch? Warning message and ASC off klas Mitsubishi Outlander 2 12-30-2009 07:18 PM
ASC off button question itoig Mitsubishi Outlander 3 10-25-2008 06:04 PM
2007 outlander - ASC TURN OFF BY ITSELF cybergoogle Mitsubishi Outlander 9 05-31-2008 01:38 PM
Tags
2007, 27, 3000, angular, asc, eclipse, fusible, gt, light, link, mitsubishi, off, outlander, required, sensor, service, velocity
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
