AC Evap Drain Location on 2003 Outlander pics
Old 07-12-2010, 03:55 PM
Grudge302gt@att.net's Avatar
Default AC Evap Drain Location on 2003 Outlander pics
After scowering the internet for a week now to try to find any info i could on the location of the AC Drain i decided to go in and find it myself after coming up short handed. You will need to remove the air filter housing to get a good view of it as i found it impossible to get to from under the car. The power steering rack and k member where in the way. You need a 6mm ratchet to disconnect the 2 bolts that hold in the air filter housing and the bolt that tightens the house to the throttle body. At that point with a flash light the AC drain can be seen.
Old 07-18-2013, 01:01 AM
paquinap's Avatar
thanks!
Old 05-21-2016, 09:23 PM
Michaelmorgan1970's Avatar
Thanks. I had this problem once before and paid ac shop 100$ to clean it out because I couldn't find the drain. This picture and recommending moving the air filter housing was just the trick. I was able to shoot some air in and it starts draining right away. Total time from start to finish was 20 minutes. Thanks for this entry.
keith6110
02-26-2014 02:08 PM
bdcorey723
07-16-2007 05:23 PM
Bearwater
08-22-2005 12:22 AM
hellsheep
08-07-2005 06:34 PM
monkey714
08-03-2004 11:31 PM
Quick Reply: AC Evap Drain Location on 2003 Outlander pics
