Conversion of J-01 MMCS into English
#84
Thank you very much for all you guys about helping to us. I have some basic questions which I need to be clear before conversion.
I have MMCS J-01 and dont have Data CD. So when my battery dies how can I use my MMCS again? Is all J-01 has similar Data CD or all has different? If all has similar I will be glad to download it if you can share. If all has different than how can I reproduce the CD?
My second question is about english conversion.
I download
engj01-LOADING.KWI
xboxhdm.zip
Do I have other files while conversion? Will I need data CD after conversion which I dont have at the moment.
Thanks in advance.
I download
engj01-LOADING.KWI
xboxhdm.zip
Thanks in advance.
#85
Do we still need HDD remove for english conversion?
I found this on youtube wich is interesting:
https://www.youtube.com/watch?v=NDh_1YqsgPY
And preparing CD's:
https://www.youtube.com/watch?v=3n4ShmJFHT8
What do you think?
And preparing CD's:
What do you think?
#86
will this work for J-03?
Will this work for J-03?
aaaaannnnnden
J-01 eng
https://mega.co.nz/#!HJFlCCia!yKWQzR...7j0lvNyk-wGZyo
Remove HDD from MMCS
Remove battery for minimum 10 minutes
Connect to IDE of PC (MMCS drive only)
Boot from CD XBOXHDM
Choose option 3 ‘boot linux with locking\unlocking utilities.
Wait for Root@Xbox-HDM:/1 Prompt
Type command
unlockhd –p <KEY>
this is the J-01 Key I used
B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFAA8C9A8DDFDF
If completed successfully typing command fdisk –l will show the partitions
Turn off pc
Run Windows with MMCS HDD connected
Locate Loading.kwi on partition with folder screendata.
Backup the original loading.kwi then replace with the new one
Reinstall HDD into car
Reconnect battery
Nek munnut….. English J-01
J-01 eng
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
#88
J-01 eng
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
I download
engj01-LOADING.KWI
xboxhdm.zip
Thanks in advance.
I download
engj01-LOADING.KWI
xboxhdm.zip
Thanks in advance.
#89
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
backwards
09-18-2014 02:05 AM
sherif_e1
10-15-2006 06:17 PM
