Detailed Rear Camera Installation
#241
Hi all, I've just made up a cable for this but I'm not 100% sure it's correct - the Red will be Video In
Green and Black are spliced together and will go down the shielding of the video in cable thus grounding - will this work? Or do I need to put one down the shielding of the video cable, and ground the other near the MMCS?
http://i1318.photobucket.com/albums/...psf6c0e55a.jpg
Thanks!!
Thanks!!
I thought you had to wire a seperate ground to the video ground.
So it would be:-
Pin 3 = Video In (+Ve)
Pin 5 = Video Ground (-Ve)
Pin 6 = Ground
So for Pin 6, don't you just wire straight to the cars chassis for ground. I thought by having a separate ground you prevent the image from having any noise. Correct me if I am wrong.
#243
Ok I wired my camera up on my lancer today. It looks really good and works well. I connected pin 3 to +Ve, pin 5 to-Ve and pin 6 to car ground.
The only thing is I got 2 lots of lines on my image. One is from the mmcs & the other is from the camera. Is there any way I can get rid of one of them or both ??
The other thing is that for now I just got power for the camera from the reverse light, I would like to find a different 12V supply that would give power to the camera all the time, once car has started. That way i can view camera whilst driving and not just when in reverse.
#244
Now it is not required anymore. I've mastered parking lines/warning removal without HDD extraction/unlocking.
#250
I haven't done it but sometimes you can run through the head liner or along the floor well where the factory wires from the back are running through...
Alternatively you can get a digital wireless transmitter/receiver set on eBay for like $20 and not worry about running wires across your car.
