Diaqueen ATF-J2 Aftermarket Fluid
#21
I am resurrecting this thread because apparently there is a new Chevron J3 subsitutue mentioned here:
https://mitsubishiforum.com/forum/mi...ueen-j2-48456/
#22
Havoline Dextron VI is certified for J2 and J3. The PDF below shows what it covers.
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
Amazon sells a 12 Quart case for under $49 with free shipping.
http://www.amazon.com/Havoline-22653...ine+Dextron+VI
#23
Amazon.com: Havoline (226535721-12PK) DEXRON-VI Multi-Vehicle Synthetic Automatic Transmission Fluid - 1 Quart, (Pack of 12): Automotive
But, just for information, Edmontonians can buy it off the shelf at the Chevron Cardlock station at 1191 168 St. for $7.99 CAD per qt. (Yes, apparently the usual rip-off of the Canadian consumer is in play, but this is still a far better price than the J3 at local stealerships.)
Edit: Also available for $7.30 per quart at Red-L Distributors at 9727 47 Ave., Edmonton
#24
2008 Mitsubishi Outlander XLS can use AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid
Applications
AMSOIL Signature Series Fuel-Efficient Synthetic ATF is recommended for transmissions and other applications that require any of the following specifications:
Ford MERCON® LV, SP; GM DEXRON® VI; Aisin-Warner AW-1, Audi G 055 005, G 055 162, G 060 162; BMW 83 22 0 142 516, 83 22 2 152 426; Honda DW-1®; Hyundai/Kia SP-IV, SPH-IV, SP-IV-RR; JASO 1-A; JWS 3324; Chrysler Mopar® P/N 68157995A (ZF 8&9 Speed ATF); Mercedes-Benz 236.12, 236.14; Mitsubishi SP-IV, ATF J2; Nissan Matic-S; Saab 93 165 147; Shell M-1375.4, M-1375.5, M-1375.6, M-L 12108; Toyota WS; Volkswagen G 055 005, G 055 162, G 060 162.; Volvo 97342
If anyone would like to know what AMSOIL products are available for your vehicle go here
https://www.amsoil.com/whymygarage.aspx?zo=1692866
Applications
#25
I'm sure you guys know a ton more about this stuff than I do...but for me...while a vehicle is under warranty...in my 15 Outlander's case..I would always let the dealer do all the vital fluid changes///especially CVT transmission fluid during the 160,000km Powertrain Warranty... if they screw it up..they would have to fix it...If I do...then not so much....just my.02
#26
After the warranty, it's not hard to do at all. Just slightly more work than an oil change.
#27
#28
I actually wouldn't. When mine was under warranty, I took mine in for a "change". They stated they only do a drain and fill...not changing it all out. That only gets a 1/4 of the fluid out. If you are going to hold onto these things for a long time, then you need to think about how your maintenance regimen is going to hold up after the warranty is done. If the dealership does just good enough maintenance to get through warranty, then you pay and they get business.
My local dealer is small but they do a full flush for $150.
#29
I really doubt they do a full flush for 150. The fluid alone costs about that much, then they charge about an hour which is 80-90 $/hr, and they still have to make some money too.
#30
Back on 09...it was 139 and they called it a fluid change. I found out after the work was done it was only a drain and fill.
