Different size oil filter ok?
Old 02-25-2015, 11:02 AM
newoutlanderfan's Avatar
Default Different size oil filter ok?
Hey all,
Have a 2009 v6 outie with 150,000km. I usually use the dealer supplied oil filter. I ran out so I bought a mobil 1 extended performance #M-1110. However, Im pretty sure it's shorter than the Mitsubishi one from the dealer. The M-1110 was what popped up on the mobil 1 site and automotive site when entering the vehicle info.
I guess my question is is it ok to have a smaller oil filter on the outlander?
(noob question I know....)
Thanks,
Dave
Old 02-25-2015, 12:38 PM
ccernst's Avatar
i've never run an OEM filter. I primarily run Purolator. If the online guide says that's the model, then that's the model. I think i've run a Mobile1 filter once before when it was on sale. I'm at 160k miles...going strong.
Old 02-27-2015, 08:29 AM
nesser's Avatar
A larger filter volume size is nice to have.
But the more important specs are matching gasket size, bypass pressure, burst pressure of the can, etc. If the online lookup pointed you to that filter for your engine's application you are all set.
The engine won't notice a 100mL less oil in the system and you should have a better quality filter media/construction for the price of the M1 vs OEM.
It's amazing how automotive folks balk at high quality $20 filters while motorcycle guys don't even blink. Good on you spending money on a quality filter.
Old 02-27-2015, 04:19 PM
Vadimus's Avatar
Larger diameter ("for honda") filter won't screw on properly and will leak.
Tepco
01-08-2013 09:48 PM
justarandomguy
06-21-2011 02:54 AM
Tony123
01-27-2011 07:50 AM
lancer0594
02-05-2009 06:48 AM
Quick Reply: Different size oil filter ok?
