ETACS options customization
#1121
Any "Lexia" Actia XS device is OK if it is not faulty. No need to hunt for more expensive versions.
I recommend using ETACS Decoder.
It does current settings backed up automatically.
Any laptop will do fine though Win 8.1 is a bit more difficult in sense of Actia driver install.
#1125
ola senhores, comprei uma outlander 2008 aqui no Brasil, o carro veio sem o módulo, porem comprei um kit módulo com chave, as peças que foram roubadas ....um eletricicista de carro passou um scan e apareceu codigo erro c 1290 ....gostria de saber se alguem pode me ajudar , o carro está bloqueado !! Agradeço desde já
hello gentlemen , I bought a 2008 outlander here in Brazil , the car came without the module , however I bought a kit with key module , the pieces that were stolen .... one eletricicista car ran a scan and showed error code 1290 c .. ..gostria wonder if anyone can help me , the car is locked !! Thank you in advance
#1126
Well done! Hooked up to the Outie just fine. Now I have no idea what I'm doing. Is there a description of the fields available to change and what they do? Or a basic tutorial somewhere?
My main objective is to get the doors to lock automatically when it is put in drive or at speed. Looks like there are several places to make changes in that regard. I'm also assuming after making changes one would encode then Write to ETACS correct?
Thanks!
Thanks!
#1130
Earl I must not be doing something correctly then. I looked on the map that showes where people with the programer are located, and then i private messaged the person that was in my area. I take it that is not the correct route to take based on your response above. Should i be posting in a public area vs sending a private message?
