Front pillar trim removal on Outlander III (2013MY)
Hi,
Can anybody suggest how to remove the front pillar trim? The plastic panel as shown in picture. I know it is attached at two points but I am afraid to break it if pulled out. Have anybody done it? I need to put some wiring behind this trim.
I just used a plastic lever to pull off the door seal rubber (watch where you grab it as the hollow section tears easily). Then the panel can be pulled off with your fingers. It is only held on with clips and it slots into the dashboard at it's base.
Careful around the curtain airbags in there, if you are running cable make sure it is run against the pillar and can't interfere with the discharge of the airbag into the cabin if it ever needs to happen.
Thanks! I will try.
Finally I've got a little time to put a cable behind the trim. As aargee mentioned, with a cheap plastic lever (see image) the trim pulled off easily. Indeed, with help of lever I pushed the trim from the side of a windshield, not rubber door seal. The trim has 2 clips: one at the top and the other one around its middle.
mlahrens
01-29-2016 06:54 AM
jrmdir
07-11-2013 09:40 PM
playback
10-28-2009 03:21 AM
2nd gen spyder 2 gauge pillar pod, autometer lunar boost gauge, and autometer lunar air fuel gauge f
mr casual
07-06-2006 10:59 PM
