Fuel Filter on 03 Outlander? In the gas tank?
Old 03-01-2012, 02:28 PM
markmisky's Avatar
Default Fuel Filter on 03 Outlander? In the gas tank?
Hi, My 03 Outlander (4 cylinder 4wd)has been having some intermittent issues where it won't start. If I spray some starting fluid into the air intake it seems to jump start it and it will start.
I was thinking of changing the fuel filter and from the parts diagrams I am seeing, it is part of the fuel Pump and you need to drop the gas tank to get at it.
It's hard to believe any manufacturer would do that. Has anyone else had similar issue and knows if the filter is actually in the tank?
Old 04-16-2012, 06:40 PM
I have an 05 and according to the service manual it sounds like it is readily accessable. I know some vehicles have a large pre-filter in the tank itself for larger items such as rust particles but the actual fuel filter should be outside the tank from what I can see.
Old 04-17-2012, 10:46 AM
markmisky's Avatar
Could you help me out and let me know what it says and where it is? I don't have the actual manual just some diagrams I found on the net. It looks like the filter is part of the fuel pump and I find no access panel to get at it.
Thanks
Old 05-14-2013, 06:24 PM
richi914's Avatar
I just change mine 2005 is inside the tank under back seat not that hard to chage if you have some experience.
Old 05-14-2013, 07:12 PM
Please check the date before you post.
CanadianOutlander
03-07-2008 11:29 AM
racerx55
1st Generation
04-11-2007 03:04 PM
cagedruss
08-31-2006 08:58 PM
anko_kun
07-31-2006 03:21 AM
gstTurbo2011
07-30-2006 02:38 PM
Quick Reply: Fuel Filter on 03 Outlander? In the gas tank?
