Installing Amp
RE: Installing Amp
take the dash apart and there should b screws holding the dash kit for the factory deck and there u go but when puting in a new deck ull have to buy a WIREING HARNESS and DASH KIT for that car.
UNLESS IT HAS TWO HOLES LIKE :[___]: LIKE THAT AROUND THE FACTORY DECK THEN ULL NEED TO GET THE SPICIAL KEYS THAT FIT IN THERE TO GET IT OUT"
RE: Installing Amp
The hole is not under the seat, it is at the base of the firewall on the driver's side.
"hope this helps, if you are talking about coming from the engine through the firewall, if you pull the carpet back under the driver side front, you should see a small perferated circle, peel that back and you can drill right there, thats where i drilled to run my amp power to the battery"
This was scalped from another topic and the info was posted by drh.
RE: Installing Amp
ok ok so its been awhile since ive been on.. life has been way busy.. if any one needs it email me and i can take some pics of my install.. everything is still messy under my seats, I havent taken the time to tie the wires together, but hey who cares when you got sound right? Anyways email me at danielhii@msn.com. Ive installed a 200w 4ch alpine to my new door speakers, cut the tweeters out for now until i can afford a component set that I want. I installed 2 12" subs inside a bypass box, a 2ch 400 watt dual(cheap amp) but it does plenty for these subs. new JVC head unit with USB interface on the front, recently installed the IPOD interface that lets me Control my ipod through the Head unit. Ill take pics of everything I can.
