Installing Front License Plate
Old 12-03-2008, 11:36 PM
Revolve99's Avatar
Default Installing Front License Plate
My front license plate fell off. I'm assuming that whoever installed the license plate installed the grommet in the wrong direction. I'm assuming the flanged end of the grommet is on the inside of the bumper. Do I access this area the same way I would If I was replacing the bulb on the fog lights?
Old 12-04-2008, 09:48 AM
mitsupartsman.com's Avatar
Default RE: Installing Front License Plate
the grommets that hold a licence bracket on work like wall molleys. make a hole just large enough for the grommet to slide in. as you tighten the screw the grommet pinches and expands larger than the hole. if its not holding its because the holes are drilled too big
Old 12-04-2008, 11:39 AM
tdford's Avatar
If the holes were drilled to big, thats great..... you could put tape or something around the groment that way it is bigger to fill the hole better.
Old 12-04-2008, 12:56 PM
Revolve99's Avatar
Thanks guys for the input. I suspect the hole is to big as i put in the grommet last night, screwed in the bolt and I was able to pull most of it out by hand. I think I might overkill it by taping the gromment up and also using an epoxy glue to hold in in place.
Thanks
Old 12-05-2008, 05:40 AM
no such thing as overkill in the securement department
Old 12-08-2008, 03:22 PM
antlip's Avatar
Did you go see if they sell bigger pieces to fit in? Would work alot better than throwing tape on and glue.
rtrackr99
06-07-2009 04:36 PM
alfman
05-22-2007 04:25 PM
XTREME
11-23-2006 02:32 AM
glassprison90
08-08-2006 10:38 AM
5Tizzle
03-12-2006 04:05 PM
Quick Reply: Installing Front License Plate
