Oil Filter Location?
RE: Oil Filter Location?
Is A LOT easier to change it from the ground (under the car) than from the hood. Is in a tight space, and the oil filter will face the ground. What that means is that when you take it off, is easier to do so under, since is facing you. If you do it on the hood, you will have to take it off in a very tight space, plus is opposide sides of you. I'm not sure if you can even do it on the hood.
SR
SR
ORIGINAL: antlip
From the ground is the easier way. You will have to let the oil pour out onto a small metal spout thing that directs the oil out. Pretty dumb way it was done and really messy.
If you want a real mess, try changing the oil on a gen2 CR-V. They make a heck of a mess unless you buy a specialtool from Honda to keep the oil from running down into the front subframe.
I have the front jacked up until I get the filter loosened and then of course put it back down and take it all the way off. But my main problem is once you have it off oil spills out of the filter. It just lands on some other metal plates no big deal, you just have to wipe oil off your car. The litlte metal spout thing works great though. They could of just put the filter in a better spot. On the work vans, the oil filter is on the bottom with nothing under it. So you unscrew and drop in the pan.
I will agree that it is in a difficult position to remove. Not much room to get to it from the bottom due to the plastic trays covering much of the front end. It looked like too much work to take off the plastic tray, so I manage to squeeze my arm up in from the bottom while laying on my back and get it off without much mess. The trick is to lossen it and letit drain while still attached, then once the oil flow has slowed down, take it of, and turn it 90 degrees so that the theads are towards the top and the oil can not run out until you have it over your drain pan. I make far less of a mess on my Outlander changing the oil than on most other vehicles that I have owned. I do the whole oil change without jacking up the vehicle at all. There is just enough clearance for me to get under it and do what I need to do.
