strange sound when turning
#32
Yes!! Another 10-15 cm's yesterday/today and into the night!
That being said, the temperature has been around -8 Celsius and a lot of snow on the ground. I have been trying to see if I can reproduce the front-end noise since my fix yesterday. So far I cannot! - It appears the grease was the issue. I have lots of wheel spin in the deep snow and no sound when turning.
#33
Update: So the noise stopped when the temperature warmed up in Calgary however I got a call from the dealer and the parts are in, they will need the car for half a day to replace the parts. I will drop off the car Wednesday night and pick it up sometime on Thursday, I will keep you guys updated as to how it goes.
Unfortunately the forecast calls for mild temperatures so I will not be able to really test if it has been fixed or not and since I hate the cold weather I am not going to wish for the -30ish we got again....lol
#34
As I mentioned I applied TSB #10-26-001R (simply grease) and have not had the sound since. It's -21°C right now in Winnipeg and no issue for me.
#37
Hi, I am having the same issue as well. 2010 XLS, the sound only comes out when I am making a left turn(grinding ice sound when there are no ice build-up in the wheel well) and especially in the -20s temp. The sound pretty much disappears once it is warm up.
#38
Take it to the dealer and they should know what to do. It should be under warranty depending on where you located.
#39
Ok, so today I brought the car in to do wheel change since winter is passed, I highlight to the person/front desk(not sure why I am not allowed to tell the mechanic instead they had to be the middle man passing the message) about this chattering noise when turning during -20 below temp.
They were not aware of this issue, and we were told to bring in the car when the weather is cold below -20. Because as long as the mechanic did not hear the noise, they wont do anything about it. I'm like, once the car warms up, the noise will be gone.
I know we can video it, or is there a official website or notes about this issues coming out from the mouth of Mitsubishi?
Mitsubishi Workshop Manuals > Outlander 2WD L4-2.4L (4B12) (2008) > Transmission and Drivetrain > Drive Axles, Bearings and Joints > Axle Shaft Assembly > Constant Velocity Joint Boot > Component Information > Technical Service Bulletins > Customer I
I have the above links...but then.....
