Vibration of steering wheel
Got an alignment at Pepboys, I still have the vibration in the steering wheel. I am being told the tire shop where I got my balancing done did a poor job. I am going to try getting them rebalanced at Pepboys. Could be a bent wheel as well. I will update if I find the issue.
Have not gone in for the rebalance yet. However did a lot of research for causes and found many others with the same issue. If you have aftermarket wheels you need hub centric rings. Only problem I do not know which sizes to buy. I have a 2008 Mitsubishi Outlander XLS,* and I purchased R-FIVE Machined Black with SS Lip wheels by LexaniŽ. 18" x 8"
What size hub centric rings do I need?
If not which size do I need?
Found these
I found these http://www.tf-works.com/tf-aluminum-...67-1mm-x-73mm/ and ordered them just waiting for them to arrive and then will have them installed as well as a rebalance.
