Engine will not start
I have a 2006 XLS 4.7 V8 Raider. It was running fine just the other day and now it will not start. It has a new battery, and I tried to reset the system by removing the positive cable, and it will not start. It just turns over and over but will not start. I took the gas cap off and put it back on, but no success. Does anyone have ideas what the problem could be and possible solution.
Thank you.
Thank you.
Solution I found
I literally just dealt with this same issue started yesterday and fixed it today. My Raider drive around the corner and shut off and wouldn't turn over but replacing the cam and crank sensors did the trick and it started right up.
IndyEndeavor
08-17-2013 11:40 AM
davehking
12-20-2007 04:56 PM
