abs problem - Mitsubishi Forum - Mitsubishi Enthusiast Forums
Old 12-16-2013, 04:50 AM
Exclamation abs problem
hi there, i have a mitsubishi pajero 3.5 gdi 3 door petrol, model 2003.
it keeps on showing an abs light together with the handbrake light!, everytime i start the car there is a continues beepwhich is un usuall to me, eventually it will stop after idling and the light goes off, then after driving few kilos and a apply the brakes, the abs light and handbrake light will pop up! i tried take it to garages, put scanner and it detect the error code 52 relay valve off it cannot clear.
can someone help me how to resolve this problem!
thank you!!
Old 12-16-2013, 01:45 PM
check connections, then look to replace the 52 relay valve off.
Old 12-16-2013, 01:59 PM
Default valve relay off error code 52
And what are these cables? If so, what calours are talkn about for me to trace them clearly!!
Old 12-17-2013, 12:03 AM
where exactly do i find the relay valve in the car?
Thread Thread Starter Forum Replies Last Post
Help! 2001 Montero XLS -- Wheel Bearing / ABS problem? bstarski Mitsubishi Montero & Montero Sport 0 11-17-2010 03:18 PM
ABS Drive Axle on non ABS 3000GT? fallingapart3000gt Mitsubishi 3000GT 0 05-13-2006 02:35 PM
evo 6 ayc abs ecu faults j22ame Mitsubishi Evolution 0 08-21-2005 06:54 PM
ABS problems 97GS NORWAY 2nd Generation 5 01-20-2005 04:25 PM
Braking and ABS problems deadweasel101 Mitsubishi 3000GT 1 07-06-2004 04:02 PM
Tags
52, abs, code, mitsubishi, relay, trouble, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
