16g turbo question
Old 06-27-2007, 05:52 PM
richieboy89's Avatar
Default 16g turbo question
I own a 99 eclipse gst and i jsut replaced the broken stock t25 with a mhi 16g turbo. car runs fine now except when i decided to floor it. it then threw a p301 code which stood for cylindar one misfire. I asked a friend for advice and he informed me that when you introduce a turbo of larger size than the original the car needs to be tuned again. I was wondering if that is the case or if i should be more concerned about something else.
Old 06-27-2007, 06:41 PM
Default RE: 16g turbo question
Your car can tune itself out of it.
Remove the battery for 5 mins, turn the ignition on to drain any excess power. Then when u put the battery back drive the car around so it can learn how to idle an stuff. It might stall... just be patient
Old 06-29-2007, 07:46 AM
RCJr9186's Avatar
a 16g is a good replacement and also has the capabilities to make around 350whp with proper setup (injectors, fmic, piping, bov, boost controller, boost gauge, fuel pump, fpr, tuning device, tune). it is also just a good turbo to haveas a replacement b/c it will run more efficient. with a new turbo you may want to invest in a turbo timer so that you don't burn the life away fromt he turbo. you can get them used for like 50 bucks these days and they are VERY simple to install.
Old 12-12-2012, 09:08 AM
turbojoe's Avatar
anybody have any after market parts for a 97 gst??? nothing crazy just bought the car stock with 118k and have some money to put into it.
get435
03-17-2011 04:33 PM
itsme71190
09-27-2008 06:26 PM
PooT_Nation
04-25-2006 01:42 AM
TheAdvocate
02-28-2006 09:13 PM
Emartoo
05-10-2005 06:12 AM
Quick Reply: 16g turbo question
