Bad turbo?
Bad turbo?
Hey guys, when im driving the car, i've noticed that whenever i let off the gas to get ready to change gears, i hear a loud screech comming from under my hood, i think its comming from the turbo. Is this normal or does this mean my turbo is going bad? Or could i be mistaken and its a completely different problem?
RE: Bad turbo?
There are two things that can happen when i turbo is going bad. If your turbo has shaft play, you will get what is called the death whine. Which is a loud whineing noise while spooling up, not when shifting. The other would be if the shaft seals have gone. Then youll end up with oil in your IC pipes and/or intake pipes. So to me it doesnt sound like the turbo. Does the sound go away when you press is the clutch?
