Turbo in a 03 Eclipse GTS
I'm looking to put a turbo in my 03 eclipse gts, i have been looking online its hard to find a turbo for a 3g eclipse, and if there is one its for the 4clyn. any help?
Club3g.com Go search. Turboing the 4g64 is a very common thing but takes alot of $ and time and wont make alot of power. The 6G72 is way more uncommon. Still done but not as easy.
Also check out MitsuOAFL.com since most of those guys have done it. I have seen a few of there cars in person.
The GTS motor is only good for like 6PSI and that is still a push. The pistons on the GTS are awful, even worse than the awful ones already used the the GT. The car will not last long if you do not put atleast stronger pistons in the motor
most people will Supercharge the 6g72 simply because it is alot eisier. Also remember you have the GTS which means you also have higher compression pistons than the GT, therefore better for NA but worse when boosting. If i were you i wouldnt waste the money becuase of the reliability. But if you really wanted to this is the route i would go
http://www.rippmods.com/category_s/21.htm
