turbo 420a help back fires
hello i turboed my 420a eclipse and im having troble with it running right after it starts up cold it runs fine for about two miles till it gets to operating temps then it stalls out and back fires it will run fine smooth and fast then dies after it dies it will start back up and idle smooth but the second i touch the gas pedle even a tap it dies and back fires and shoots out a fire ball i thought it was two big of injectors so i put stock back in it and that did not help so if anyone knows whats goin on with it or knows how to fix it i would appriciate it thanks. also when i disconect the boost pip and run na it does the same thing now
