Mitsubishi Grandis
Mitsubishi Grandis Warrior DI-D
Hi There
I was just wondering if anyone had any ideas to what my problem could be.
I have a Mitsubishi Grandis Warrior DI-D 2005.
When I am driving it I get a loss of power and a lot of black smoke then after about 30 seconds it clears and it runs perfectly.
During the loss of power when trying to rev the engine it pinks/rattles a littl then clears.
I have had the turbo reconned, replaced the following parts, EGR valve, Mass airflow meter, Throttle body and map sensor. Any ideas would be greatly appreciated.
Kind regards
Kevin
Kind regards
Kevin
Hi everyone,
The front right ABS sensor on my 2007 Grandis (2,0L DID)is apparently broken.
I can only find spares for the 2,4L Petrol version.
I was wondering if anyone knows if it is the same sensor on both versions?
Are the front disk brakes the same?
Thanks in advance.
Thanks in advance.
[font][font][QUOTE = tmd_63; 198139] Postează aici pentru toți Mitsubishi Grandis [/ QUOTE][/font][/font]
Hi, I have a mitsubishi grandis 2.0 diesel bsy engine. for a while, I have a problem - the car starts well, goes well, but when the water reaches 85 degrees, the engine dies suddenly, and can only start after 10, 15 minutes. I have the error U1101. can anyone help?
Help
Hi new to this forum and finding it a bit difficult to post a question so this is more than lickely in the wrong place.
Anyway i purchased my grandis not long ago with a few faults 1 cut out randomly 2 limp mode so checked ith OBD11 this is what came up P0335 crank shaft sensor new sensor fitted / P0234 boost preasure sensor new sensor fitted /P0401 and P0488 cleared faults now down to 2 faults P0236 and P0236 pending BUT my EML light is taking longer to come on for instance switch on after repairs the light came back on now it does not come on till about 5 /6 cycles any ideas and sorry for the long post
Have same problem
Mine is an 03 but also has touch screen
shiman
Other Mitsubishi Models
10-24-2013 05:47 AM
20, 2003, 2008, code, diagnosemitsubishi, grandis, immobilizer, mitsubishi, mmcs, oil, override, problem, recomme, screen, suspension
